Hello,
Just bought a 32" avant CRT. However, i need to shift the picture more to right. Are there any hidden settings on the remote or in the TV?
Have a look at this. Here is how to access the service menu on the Beovision 3. I think it's the same for the old Avant.
http://archivedforum2.beoworld.org/forums/t/12153.aspx
Make a note of all the settings before you change anything!!
Peter
thanks, but I cant find anywhere in the link how to actually access the service mode. I am probably blind :)
Press TV, then MENU. Scroll to the SETUP line and then press GO, 0 0, GO.
