Hello everyone! when I connect an ipad in the Beosound 9000 aux. connector, sounds good but when I connect the AirPort Express does not work and it feedbak. The same AirPort on a regular amp works ok. Can anyone help?
Beosound 9000, Beolab 8000, Beolab 4000, Beolab 2000, Beo4
That should be impossible..
Check that the cable connector and the input on the AE are clean?
PVoyer:Hello everyone ! when I connect an ipad in the Beosound 9000 aux. connector, sounds good but when I connect the AirPort Express does not work and it feedbak. The same AirPort on a regular amp works ok. Can anyone help? Beosound 9000, Beolab 8000, Beolab 4000, Beolab 2000, Beo4
Hi PVoyer and welcome to Beoworld,
which button on the remote do you press?
What kind of cable are you using for the connection?
This kind of combinations has been used a lot - several user on the forum does that with good results.
I am sure we/you will find a solution.
