I've just recently bought an NTSC Wii. For some reason, I can only get a black and white picture on my MX7000 and Avant TV's.
I'm using composite and s-video cables.
MX7000 is on software 2.0.
Avant is type 8133.
Any help appreciated.
Strange... all the specs I've read seem to indicate the sets should handle NTSC.
The MX7000 even has a "Tint" setting... which apparently only applies to NTSC signals.
I'm guessing the firmware is the same in all territories, meaning the tint function is redundant here?
jimbobjim:Strange... all the specs I've read seem to indicate the sets should handle NTSC. The MX7000 even has a "Tint" setting... which apparently only applies to NTSC signals. I'm guessing the firmware is the same in all territories, meaning the tint function is redundant here?
I see. If I were to buy a later MX on a higher FW, would that work? Or are there any other options (CRT wise)?
Thanks for all the help so far.
I have an MX7000 with SW 4.5 on the hook. Should I buy it?
The MX7000 was an awesome TV, we had one for years. If it's cheap and what you want, go for it. And it goes on a motorised stand too for ease of use. Sound was great from it.
Dave.
Hi Dave. I already have one on software 2.0. Just need to know if the later ones support NTSC.
They are indeed, great tellies.
Just an update for anyone that might have this problem. I had to buy a YUV to RGB scart converter. Works flawlessly.
http://www.js-technology.com/store/product.php?id_product=16
