BS2500 + beolink passiv
This post has 3 Replies | 0 Followers
Silou
Switzerland
Posts 465
Silou Posted: Mon, Nov 3 2014 8:15 AM
hello,
In the main room: BS2500 + BL2500.
In a second room BL passive. Powerlink connector connected to the BS2500
Does it work?
Thanks!!
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Nov 3 2014 11:41 AM
Hi Silou,
yes this should work, but the volume will be controlled from the main room and the second room will get sound every time you listen to music in the mainroom.
If you want different volumes in both rooms or just music in the second room you need a masterlink connection between the BS2500 and the second room. To get a masterlink connection to your BS2500 you also need a BeoLink converter 1611 or 1614 The Beolink passive needs an IR eye (puck) to receive control commands from your B&O Remote controller (BL 1000, Beo4 ...)
Hope this helps
Ralph-Marcus
Silou
Switzerland
Posts 465
Silou replied on Mon, Nov 3 2014 1:24 PM
Hi RaMaBo,
thank you for your tips.
i would like different volume in both room or just music in the second room.
Also I need necessarely the converter. I this way, I suppose Aux connector's BL2500 into the converter then ML cable to the second room.
Right?
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Nov 3 2014 1:31 PM
yes that's correct the AUX cable is needed to connect the BS 2500 to the Beolink converter. A powerlink cable is not necessary from the BS2500 to the Beolink converter. I have a the same setup but with a BeoLab 2000 instead of the Beolink passive and passive speakers.
Ralph-Marcus
Page 1 of 1 (4 items) | RSS
