Is it at all possible to add WiFi to a BEO 5500 via the aux port?
I am finding that I dont use this system anymore. Instead I am using my Wireless Play in local mode.
Hi there.
Yes - you can add any wifi device you want to the AUX port. An Apple Tv, a WD TV Live box, or whatever wifi device can be connected.You can also add a Bluetooth receiver to the AUX, if you want that.
I have a WD TV Live box connected to my Beosystem 9500 (and my TV). I can stream from my phone, tablet, computer, server - whatever I want.
And - the good thing is, that it works with iOS, Android and Windows.
