Use beosound Century with SONOS
This post has 3 Replies | 0 Followers
matbkk
Posts 43
matbkk Posted: Mon, Nov 24 2014 4:41 AM
Dear All,
I have a BS Century that I like and I am wondering it is is possible to use it with the Sonos System ?
Thanks by advance for your replies,
Matthieu
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Nov 24 2014 8:24 AM
matbkk:
Dear All,
Matthieu
It should be possible to use the Sonos 'Connect'.  At least according to Sonos:
http://www.sonos.com/shop/products/connect
You should then be able to expand the system if you want.
How were you thinking of utilising the Century with a Sonos system?  What do you want to achieve as there may be better options?
Dave.
Millemissen
Flensborg, Denmark
Posts 14,680
The Century has an Aux-in - you can connect the 'Sonos Connect' to it.
In order to use the volumen control of the Century as usuall - via Beo4 or directly - the sound-output from the Sonos should be set to fixed line-out.
Of course you will have to choose the Aux of the Century - again via Beo4 or directly - before you start feeding the Sonos with music.
Tip! If you combine the timer function of the Sonos with the one of the Century, you could even use it for waiking you up in the morning - as an example.
The Connect has an 'analog input' - you could use that for a turntable, if needed.
The analog and the digital outputs are all active, and can be used at the same time. If you have a BeoVision nearby/in a nearby room, you could use the digital out to feed the television in order to hear the music from the Sonos through the (connected) speakers too. And if it is a BV with MasterLink, (dependent on your setup) you can even use that source in every link-room.
matbkk
Posts 43
matbkk replied on Mon, Dec 1 2014 2:04 AM
THank you guys for your reply.
I will install the system over the week and I will let you know if I encounter any problem
Mat
Page 1 of 1 (4 items) | RSS
