We've a BV6 23 in our kitchen and are happy with it. The picture comes to it through the coax as a link TV. The picture is ok, but i'd like it a bit sharper. If I got a BV6 26 HD will I gain anything or is the coax going to limit the picture too much?
Thanks, Andrew.
How does the B&O BeoLink RF Link Amplifier work? Would that boost the signal?
What is the source of the TV signal? Is it via a STB? I found a hidden menu on our STB for picture sharpness and put it from the factory default of 10 to the max of 15 and it's made a huge difference on both LCD and plasma TV's.
Lifestyle AV have the RF amp. Give them a ring.
Dave.
Dave Farr:Lifestyle AV have the RF amp. Give them a ring.
And ask them whether boosting a digital signal works -- I had no luck tricking mine into working (happy to acceptance that it could be my incompetence).
BeoNut since '75
There is no 'boosting' - it is exactly the same quality as the analog sd channels (used to be).
A 'bad' antenna installation could make it worse.
However - if the source is good (and the cabling is ok), the signal on the link-tv will benefit from it.
