I have two LC2´s in the same room.
They are set up as "lamp1" and "lamp2".
When I press "light" on my beo4, I have to press list 9 times before it shows "lamp" in order for me to choose what lamp to control.
I want to move "lamp" to show first when I press "list" after pressing "light".
"Lamp" doesnt show in the menu at all when I go into the setup of the Beo4.
Anyone that can help me with this?
Unfortunately older Beo4s don't have the MOVE function. I believe you can circumvent this by deleting everything from the list and then adding the functions back in the desired order.
--mika
My beo4 when you press light once it shows light and works fine with LC2/3
