Hi I was about to turn over the tv channel but then got caught up in a discussion I turned back to the tv to notice that it is displaying a small picture in the top right corner which i just cant remove back to full screen.
Help, im using a beo4 remote, I have checked the guides and cant find the setting,
Kind regards
i don't own a BV8 but you could have accidentally gone into Picture in Picture mode. it should return to normal when you turn the TV off and on again
Thank you for your message, I did end up turing the tv off then on and it went away but not afer hours of looking throught he guides........................
Thank you for your message, I did end up turing the tv off then on and it went away but not afer hours of looking through the guides........................
