The muting relay doesn't open until the record has just started. Is there a way I can make it open a little quicker?
I'm not sure if this applies to all versions of 4002, but if there is a trimpot on the same small circuit board with the relay, it should be for exactly this purpose.
The adjustment is probably at the spot where it was when the deck left the factory, so the trimpot may just be oxidized.
--mika
