Hello,
Looking for information on the Datalink protocol to connect (and control) a non-B&O device to an older B&O set I found your tech pages.
Alas the link with the zip file on the bottom of this page: http://beotech.beoworld.org/datalink.htm does not work, it just sends me back to the home page. Is the file still available somewhere?
Gert
Hi Gert,
the file is available somewhere but I don't remember where. The question, though, is how you want to connect to the unit (and what unit it is)? Is it through the 7-pin connectors or the speaker sockets? It will make a world of difference. And the file only gives some hints (not much at all) about the speaker socket connection.
Either way it shouldn't be too difficult if you're stubborn.
/ Johan
