i have just received my new Beolab 17 and I am planning the installation of the Essensce and Transmitter 1 inside a kitchen cobert.
I would be grateful for help on how far away should be both units be. Can both units be on the same shelf? Should I install each unit in a separate shelf to avoid interference?
thanks in advance for the advice
Hi and welcome to Beoworld,
that should be no problem.
Just put one on the other to avoid longer cables.
But do remember that a microwave oven easily can disturb/interrupt a wireless transmision.
