beogram 4002 ..not playing
gman
Posts 1
gman Posted: Sun, Dec 28 2014 11:35 AM
Hi all,i have a beogram 4002 and it does not want to play but the  lp turns.The needle arm thing does not drop on to the lp,i have checked and lubed all the links that have to do with the solenoid but still nothing ...any ideas what it could be ?
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 28 2014 12:24 PM
The solenoid has failed - the Beogram should make a click sound as the arm reaches the correct drop point. If the solenoid fails, the arm stays in the up position and no click. I would get it to a service department if you are not used to dealing with electronics as the 4002 is not really the place to learn!
Peter
Page 1 of 1 (2 items) | RSS
