Correct voltage for B&O infra-red code converter box
This post has 1 Reply | 0 Followers
Lee
Newcastle upon Tyne UK
Posts 734
Lee Posted: Wed, Jan 14 2015 5:22 PM
Hi guys,
Can anyone tell me the correct voltage for the Bang and Olufsen IR code converter?
Its the box that converts the newer IR codes to older ones for the BM5000, 6000, 8000
Thanks in advance,
Lee
Premiumverum
Netherlands
Posts 115
The text on the converter says 8-14V DC. Mine has an adapter that used to be from a phone, 9VDC 500mA with the + on its sleeve and the - on the pin, so inverted from what you'd expect from most adapters!
Page 1 of 1 (2 items) | RSS
