Have a beomaster 2402 which the local B&O dealer has been trying to repair for the past 4 months with no success. Does anyone know of anyone in the Newcastle upon tyne area or north east who would be able to take a look at it.
Cheers.
Many thanks have emailed martin and will see what he says
Hello I suggest you contact Quality Dream Audio (Ray or Helen) - I have found this company brilliant and you are able to post the 2402 down to them and they return it well packaged. I live in Northern Ireland and anything that I have sent over or got returned has been excellent. Cannot recommend them highly enough.
Hopes this helps
Professor David A Flynn JP LM
Thanks for this info however will first try Martin in stockton as this is only an hours drive away,l am reluctant to trust a courier with handling this
Thanks again
