Whistling noise/ water running noise from beo5 plug/ lead
This post has 2 Replies | 2 Followers
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Sun, May 27 2012 12:29 PM
When I charge and only when I charge my beo5 I can hear and whistling noise/ water running noise coming from the plug or lead. Has anyone else had this issue? The lead appears to be in perfect condition and along with the plug.
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Ronnie
Milton Keynes, UK
Posts 110
Ronnie replied on Sun, May 27 2012 6:59 PM
Not sure, try changing the cable as sounds like some sort of loose wire etc, or the voltage is wrong or something.
Chris Harrison
Peak District
Posts 381
Spoken to my local B&O dealer and it is basically the transformer in the plug that is broken. I need to take it back to them regarding warranty on the item.
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
