Hello,
I own a BeoVision 7, a MacBook Pro and IPad. I'd like to send the sound & image from my macbook or IPad to my TV. Do you know if I should buy an Apple TV for that? Is Apple TV compatible with a BeoVision 7? I am not sure how to connect it. Thanks a lot for your help.
Chris
BeoNut since '75
Hi Elephant and thanks for your response. unfortunately, my BV7 does not have an HDMI socket but only DVI... Anything I can do to connect the Apple TV?
