Hello together !
My beautiful ancient BEOVOX 4700 speakers have 4 Ohm.Question to the technicians: Can they work with tuner/amplifiers which require 6 Ohm ?Or alternatively, can such 4 Ohm speakers be modified in a way that they will work with 6 Ohm requirements ....might be a silly question.
Anyway, many thanks for comments!
regards, Rob
It will work fine. The 4 Ohm is a rough estimate - the actual load varies massively depending on frequency.
Peter
