Lutron Radio Ra
This post has 0 Replies | 0 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sun, Feb 8 2015 2:31 PM
Hello Beofriends
I think i would like to have Lutron in my kitchen at first glance. I Already have 10x6W LED lights by JCC installed and currently these are switched via a single light switch, there is in fact two zones one half for kitchen and another half for dining room but at the moment they switch as one.
I think i would like Radio Ra / RA2 to control the LED lights in my kitchen so i can add them to the Beolink Gateway when i get up and running.
I have some questions for any of the Lutron Guru's out there
What switches could i use to control the two zones ?
I understand i will need a RFlink of some sort to connect from Lutron to Ethernet. what is that model number?
How deep are the switch units?
I am lucky in my kitchen as the positive and negative feed are both in the back box so maybe even a Grafix eye would be possible but i would like to do as much as possible without having to put in huge deep back boxes.
My middle room is just a normal switch one single cable and a bulb so i think either a Lutron solution or Phillips hue would be fine.
Any Lutron experts out there who can fill in some of the gaps?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (1 items) | RSS
