leosgonewild:If only Spotify would move the EQ to the actual play-screen, and not have it hidden all the way BACK in settings
Agree. Deezer have a better implementation of that actually.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Is it worth an upgrade from a working(!) Beolit 12?
My opinion, and MY opinion only:-
BL12 narrow stereo vs BL 15 mono in all direction (BL15 wins)
-BL 15 has fuller bass (I like it better)
I am happy I upgraded, but I had issues with my BL12.
The BL15 will be wonderful to take outside during summer for wireless use. The BL12 needs a wire if it is not on wifi.
If you use your BL12 only at home, and the placement gives you a good bass, I would not recommend changing since you are not experiencing problems with it.
Bear in mind that I have been using it for one hour only.
I would say that the BL15 vs the A2 is like comparing my VW Golf VR6 with a Fiat Punto.
Epic comeback, Chris!
TWG:Is it worth an upgrade from a working(!) Beolit 12?
This is spectacular - why does B&O not advertise it? Clearly fits my usage pattern. :D *yay*
Chris Townsend: Can you compare it to the 12 at all?
The BeoLit 12 have got a more classical conception - 2 tweeters with 1 boomer.
It sounds clear, neutral and powerfull. It is perfect for room inside.
The BeoLit 15 have a "space sound" with 6 speakers oriented in 360 degrees.
The bass are more present and tweeters seems filtered. This design is ideal for outdoor party.
Personally, I keep my BeoLit 12.
So BeoBoy do you feel that the BL12 is situated better then in say a book case with other items, where it is one directional, as opposed to a multi directional?
Id still like to try it out in person over the BL12 and let my ears do the talking :-)
Aussie Michael: So BeoBoy do you feel that the BL12 is situated better then in say a book case with other items, where it is one directional, as opposed to a multi directional?
Just a personnal taste.
I hear lot of classical jazz and I prefer the BeoLit 12.
If it is positioned near a wall or it sounds phenomenal.
BeoLit 15 sounds better in a middle of a room or outside.
It seems that his design was done for electro pop music.
I can speak for the Beolit 12 quality. It is very good. The sound is full, and powerful. The battery life is consistent, and after more than 2 years, there have been no issues at all. It's a stellar little device with solid physical build. Just a shame about the cumbersome airplay function which I have seldom used.I love the look of the Beolit 15, the new colours are a nice change. I'm particularly wooed by the golden champagne colour. Calm down peeps, I'm certain B&O will release other colours soon after it's been on the shelves. I might buy one further down the track once it's been out for a while, as it's nice to take music down to garage while working on the car or doing work outside the house.
I'm not surprised that their Tonmeister wasn't employed to assist in the development of the Beolit 15. I don't know why B&O would, it's merely a playful little boom box, not a pair of audiophile grade loudspeakers, and it's priced accordingly.
The IR will be missed, for those with an ipod sans bluetooth. I use an ipod classic connected via usb, so with that I can change volume and skip/ fast forward / rewind tracks with the Beo 4.
