Beolink App
This post has 6 Replies | 3 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Thu, Feb 26 2015 7:57 PM
Hi all
When you are in a zone with a source switched on in the room with s device that is sending its status to BLGW should the app always start showing which source is on?
When I open the app I have to press the source that is already on to control it?
How do I test if my bv7 is passing control commands back?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Thu, Feb 26 2015 9:10 PM
unfortunately not;
i don't think the two way works that way ;
if you select the source with your beo4 then the beolink app won't necessarily know
what you're turned on
PhilLondon
London
Posts 3,637
PhilLondon replied on Thu, Feb 26 2015 10:25 PM
I think I read that an update to the app for 2way is on its way.
Beoworld app with direct photo upload and emoticons.
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Thu, Feb 26 2015 10:42 PM
PhilLondon:
Beoworld app with direct photo upload and emoticons. Other apps: The Story Mouse . Grignan guide .
Cheers guys that would be great for the app to be up to date with what each room is doing especially if you are away from home and port forwarding.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Thu, Feb 26 2015 11:37 PM
Correct
Two way is coming but I don't know that it will report B&O status.
And certainly won't report ML product status.
Steven_London
Posts 51
Correct, two way is coming, I asked my dealer if two way feedback from the Beolink devices would be added, he didn't know but said he raised the request with B&O. I wanted to use the BLGW to change lighting when turning on sources either using the App or remote control. The way I see it was turning on TV would dim the lights and close the blinds say.
mjmedlo
Posts 922
mjmedlo replied on Fri, Feb 27 2015 7:38 PM
Steven_London:
You are able to do that now with the blgw.
Make the 'TV' command a trigger that changes lights and shades.
Page 1 of 1 (7 items) | RSS
