I cannot figure this out from the B&O website or the BS5E manuals.
Is it possible to use the BS5E in an integrated way with the BV10 and Beolab speakers?
Regards,
F
- Flere
smile and enjoy the moment
Hi Flere,
I doubt it because BS5 Encore does not have a Masterlink socket.
You might ( honestly I do not know ) be able to connect the BeoLabs to both, BS5 Encore as well as the BV at the same time but I would definitely not do it that way.
Lars
BS9000, BC6, BC2, BL3, BL11, BL3500, BL2000, BeoTime, Beo EarSet2 3i, Beo, BEO DropStop, BEO Bottle Opener, BeoCom5 including Table Stand, ATV
Christmas Prize Draw 1st Winner 2010 - THANKS A LOT!!!
Struer Trip 2012 - THANKS A LOT!!!
