I picked up ne of these recently and was looking for a surce of belts and cables for attaching speakers and belts for the turntable and cassette deck. Any good sources out there?
Thanks for any help you can give.
Joe S.
Martin (Dillen on site) can provide a full set of belts. You can either make your own cables using 2 pin DIN plugs or buy ready made ones - pretty sure B&O still can supply them.
Well done on getting a 7700 - probably the best record based music centre ever made.
Peter
