this maybe a silly question to some ....
My BeoCenter 1 just died (RiP it was a great looking set) and I've just replaced it with a 6 26 (with HDMi & Freeview).
Ok I'll use HDMi for another Apple Box but how best is it to connect to the BeoCenter 2 (with DVD) for best picture/sound quality ? Masterlink or SCART ..
ps for those who know me my wife took the sighting of another B&O unit really well
I may be wrong here but I think you need to use both. If you check out the user manual in the products section it shows this and I seem to remember needing to do this for my system. For full functionality you will need both - for remote operation etc.
Dave.
Dave Farr: I may be wrong here but I think you need to use both. If you check out the user manual in the products section it shows this and I seem to remember needing to do this for my system. For full functionality you will need both - for remote operation etc. Dave.
Agree. My BC2 connects via scart and Masterlink (to a BV5). My ex demonstration BC2 was supplied without the Masterlink cable causing several hours of confusion!
Graham
thanks Dave & Graham much appreciated..
