I know an older gentleman with a passion for B&O, and I sometimes have to help him with his equipment.
He has a Beocenter 9500, and he has recently bought a Master Control Panel 5000.
He wants me to help him with it, because he is having some issues.
Before I go there I would like to ask if the MCP 5000 and the BC9500 are at all compatible? I suspect they are not..
No they are not compatible at all, the only device the MCP5000 will work with is the Beomaster5000.
noo
Just as I suspected. Thank you for quick information.
Lee: No they are not compatible at all, the only device the MCP5000 will work with is the Beomaster5000.
That was close!
I suggest, he wanted to buy a two-way-remote like a Beolink 5000. A Beolink 7000 will also do. But pay attention with the displays of the 5000, they are often loose and lost contact to the mainboard. This is not repairable.
