Beocenter 7000 MCL82 query.
This post has 6 Replies | 0 Followers
bigphil
Posts 69
Silver Member
bigphil Posted: Sun, Mar 29 2015 6:24 PM
Hi I have a 1981 Beocenter 7000 and I want to have an MCL82 link upstairs.  I have seen a few on Ebay, I presume the control panel that goes onto the wall is connected to the relay box via the 8 pin din cable and the stereo links to the link 1 socket,  with the master control cable?  Is this cable connected to the speaker 2 output? Then the upstairs speakers connect to the left and right sockets on the relay box? Hope this makes sense??
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Mar 29 2015 6:59 PM
Yes - the 3 pin DIN sockets come from the speaker 2 sockets and supply power as well as a control circuit. They work well.
Peter
bigphil
Posts 69
Silver Member
Where can I get the 3 pin plugs to fit these sockets for the masterlink setup?
bigphil
Posts 69
Silver Member
bigphil replied on Mon, Mar 30 2015 7:56 PM
Where do I get these plugs please. Cheers Phil
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Mar 30 2015 9:15 PM
I got mine from B&O. Maybe Steve at Sounds Heavenly can help?
Peter
bigphil
Posts 69
Silver Member
bigphil replied on Mon, Mar 30 2015 9:46 PM
I've managed to source a pair of plugs from Steve at Sounds Heavenly.  He doesn't stock the cable do you know what cable Is need and where I could get it.  Cheers Phil
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Mar 30 2015 10:42 PM
Not completely simple! It is not just 3 core or 6 core wire as can be seen in the wiring diagram. One of the wires needs to be shielded and MCL wire carries amplified signal so it needs to be reasonable quality. I was given a roll of this some years ago but I am afraid over the years I have given it away. Definitely worth asking your local dealer as they often keep wire as it doesn't take up too much space. Otherwise I would suggest mains cable but in three separate wires keeping the data signal separate.
https://www.beoworld.org/beotech/wiring1.htm
Peter
Page 1 of 1 (7 items) | RSS
