Hi
I have some old Beovox S45s ( Beocenter 7007 ) I'd like to try and re-foam myself.
Can anyone suggest someone who sells B&O certified / compatible foam suspension for my speaker woofers please?
Thanks!
B&O no longer support the older speakers and there is no way they will 'certify' any foam rings either, much as they will never support any replacement parts apart from original B&O ones. You could try these people for foam rings:
http://www.simplyspeakers.com/bang-olufsen-foam-edge-repair-kit-fsk-8.html
I haven't used this company but they do come with recommendations. They also now sell rubber surrounds if you prefer for the same size speakers:
http://www.simplyspeakers.com/speaker-rubber-edge-repair-kit-rsk-8.html
Alternatively, these people in The Netherlands sell foams I have used before with no problems:
http://www.ebay.com/itm/Schaumstoff-Sicken-fur-Bang-Olufsen-S45-S55-3702-uzw-2-St-gratis-Versand-/251312085494?pt=LH_DefaultDomain_77&hash=item3a835e19f6
Dave.
