Instead of the rectangle IR sensor, would it be possible to use the more current round IR sensor with an older MCL2A?
With the round IR sensor, would the MCL2A respond to both the Beolink 1000 IR commands and the hard volume buttons of the IR sensor?
Many thanks!
It looks like it does not work: http://archivedforum2.beoworld.org/forums/p/2260/19529.aspx
Or does anyone have another experience and aws able to use a sensor with hard volume buttons together with an MCL2?
Many thanks in advance!
Looks like it does not work: http://archivedforum2.beoworld.org/forums/p/2260/19529.aspx
Or did someone find a solution to use an IR sensor with hard volume buttons together with an MCL2?
