Hi Folks,
I recently turn up my beloved Beosystem 7000 CD + AMPLI in black and white and notice a strange problem on the CD compoment :
Upon inserting a disc and pressing play, I heard the CD spinning, sometime its gets till the AMPLI display the index of the tracks, but it always shuts down automaticaly before playing. I try numerous CD, both paid one and one I made myself, and I observe the same behaviour.
I have the chance to own the CD+AMPLI setup both in black and white, I made several tests and the 2 CD units seems faultly (needless to say, I am trying to sell them and last time I test them, they were working...).
Do you have an idea of the problem ???? I am clueless on this. Any help will be appreiciated :)
Cheers,
Sergio
thanks for the answer !
Yes, I try different CD, no luck at all. Sometime, with luck, it works, but another time with the same CD, it doesnt...
Regarding the fault capacitor, how can I diagnose that ? Or check it ? A few years ago I already open the CD and AMPLI box in order to clean them up from dust, so I am not afraid to open the CD and check for electronics !
Cheers
It can be this capacitor fault. I do these repairs for many years...
Even with a 100% replacement of ALL capacitors this defect is seen more and more. It is the laser unit itself that fails.
10 years ago 90% of the cd7000 failed because of caps, especially C2103 and power supply. Today i get more than 50% players, where the laser unit has one or more ( of 4) damaged laser receiver diodes and have tracking problems. This is not repairable any more...
Try this: start cd, turn off Sound. Listen to the drive. if there is a Sound, becoming louder to a singing or humming noise... laser tracking unit defect. Unrepairable.
Also skipping and not holding the tracks has to do with this defect.
Sorry for the News...
Thanks a lot for this answer.
I try to listen to the sound of the CD, but everytime I press play, I heard it spinning and stop. it lasts around 1sec, maybe 2, but it always stopped.
I clean a little bit the undercover and my Black system is working again (for how long...). The White one is not anymore.
Do you think I can do something ? Regarding your answer mine may not be totally dead... :)
