BEO6 Brightness/Battery
This post has 3 Replies | 2 Followers
hanijonathan
Posts 6
hanijonathan Posted: Sun, May 3 2015 3:36 PM
Hi All.
I recently bought a Beo6 on Ebay, unit is meant to be brand new.
Screen brightness seems a bit on the dimmer side. I do not have any other Beo6 to compare mine to, what i noticed is when i power it off and back on, first 1-2 seconds screen is nicely illuminated and bright and then goes dimmer and stays like this. Is this normal? can someone try this and let me no, powering it off and back on. Is there any hidden brightness module?
Another weird thing happens, when i connect it to a computer through USB, battery no matter how full it is is immediately drains down to 0% and asks to recharge. I did leave it on stand by for 3 days though and it kept charged, didn't drain.
Thanks,
Hani
BeoSystem 5000 - Beosound 2 - BeoCom 1000 - BeoTime - BeoVision Avant VCR - BeoVision 5 - Beo6/4 - BeoPlay A9 (v2) - BeoPlay A8 - Beolit 15 - BeoPlay H8 - BeoPlay H6 - BeoPlay H3 - Form 2i - BeoPlay A2
Amazone
Netherlands
Posts 187
Amazone replied on Mon, May 4 2015 6:46 AM
Both are normal.
you can change the display dim settings in the menu, after pressing red+go
It discharges completely after downloading a config from your pc. After a few minutes charge however you are able to dowload again. It is a bit of a hassle though.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
hanijonathan
Posts 6
ok thanks!
hanijonathan
Posts 6
ok thanks!
Page 1 of 1 (4 items) | RSS
