What type of USB cable plugs into the female USB end of the wire connected to a Beo5/6 table charger cable?
I acquired a remote and table charger but don't have the actual USB cable to plug into a computer or usb power plug.
The female end doesn't match any USB male ends in the small bin full of USB cables I have on hand.
Is this a proprietary cable only from B&O?
So I think it is just a mini USB type B, although I've never seen the female end of a Mini USB type B shaped that way before. Type B male connectors are shaped slightly differently.
It must be a deprecated usb type AB mini connector.
Hi Sal,
This should be the cable you are looking for
http://www.ebay.com/itm/USB-2-0-CABLE-AWM-E89980-A-SUNF-PU-STYLE-2725-28AWG-1P-28AWG-2C-/181725594227?pt=LH_DefaultDomain_0&hash=item2a4fb08273
Hey, Sal. Any chance that you have a Canon digital camera? I seem to recall that I found I could use the usb cable for my camera. Some external hard drives might come with that type of cable, too.
Thanks to everyone for your comments, I can confirm that I have a TON of these USB cables. The Female end of the B&O cable was throwing me off!
