I have tried to set the internal clock on the BeoSound 1 by following the instructions ie << and >> simultaneously and then hold together, but instead of a flashing light to enable you to set the internal clock I am getting 'AU' on the screen. Can anyone help?
David
Professor David A Flynn JP LM
Your BeoSound1 my be version 1, which has no clock. Same as mine :-(
hfat
