BeoGram6000 Typ 5512 output signal goes silent intermittent
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Sun, May 24 2015 3:44 AM
greetings all,
i posted that problem previously Sad
in the meantime I replaced the SIEMENS muting relay on the main board with a new one and the output
signal still goes silent from time to time ?? comes back after a while, drops out again and sometimes play for half a day without a problem !!
finding the 'nasty' seems difficult as I can not detect a pattern here.
could it be a problem with the RIAA pre-amp ? just guessing here.
or is a voltage breakdown at the muting relay likely ??
when the signal drops out it goes out instantly without a crickle or crackle or any distortion-foreplay and comes back just as quickly.
don't just want to change parts blindly on the off-chance to have got the sick one.
anybody out there who might have a better idea or suggestion ??
I am simply stuck with that problem........ Lightning
cheers ALF
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, May 24 2015 6:04 AM
If we agree that the main board is the one under the platter, fitted solder side up, it doesn't handle the muting at all.
The relay on that board is for speed switching 33/45.
If no decoder is fitted in your deck, (that's a heavily populated board sitting under the operation panel, component side up) there
will be a muting relay on the board fitted instead and only about a handful of other components.
This relay will merely ground the output signals, it won't break the signal path. This means that in case of intermittent contacts
the sound will (intermittently) NOT be muted, resulting in audible thump sounds when the cartridge lands on the record.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Sun, May 24 2015 7:33 AM
Hello martin,
Thank you for responding - we can agree the main board solder side up is under the platter - has a fairly large Siemens relay fitted - now a brand new one !
The board under the control panel - board 6 - is heavily populated, so this one must be the decoder - I plug the table straight into a line-level input.
The board under the 4002 control panel only has a few components in contrast.
Anyhow, does that mean the muting circuit sits  on the decoder-board but has nothing to do with th signal drop-outs ??
It Is tricky to describd the sound it makes when the signal drops in or out.......probably sounds more like the stylus makes a mild 'crash-landing'
on the record ?!
Am I still barking at the wrong tree here or is the problem decoder-output related ??
ALF
Dillen
Posts 13,191
Dillen replied on Sun, May 24 2015 7:48 AM
The main board does not handle anything sound-related. That's all done on the decoder board.
If the problem affects both channels simultanously, the problem must be in a common circuit.
Intermittent faults can be tricky to cure but check the power supply for correct voltages and amount of ripple.
If all good - put a scope to the signal path and see where the signal is lost.
Local cooling/heating could also help narrow down the problem area.
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Mon, May 25 2015 4:27 AM
hello martin,
yes, of course the 1RL1 handles the speeds......just looking at the circuit diagram says it all !
must say, I had been misguided by someone pointing out to me the RL1 Siemens relay as the muting relay :-(
perhaps a simple misunderstanding ?!
well, quite right: intermittent faults are just what one needs !
both channels are simultaneously affected by the signal drop outs/ins.
that could not be caused by a single transistor or capacitor as I understand it ?!
I shall have another look at the Board 6 diagram, although I have to admit I am getting into DEEEEEP waters here ........
where staying afloat is the issue
cheers ALF
ALF
AUS
Posts 1,015
Silver Member
hi martin,
I took 2 shots from the decoder board in my table to better illustrate my concerns....
also find it hard to match with the service manuals available as most of these boards seem to look different ?!
that big fat blue 1000uF cap looks suspicious with corrosion on its lead wires !
cheers, ALF
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Sun, Jun 28 2015 4:37 AM
quite right what martin pointed out - thanks !!! - intermittent faults are difficult to trace but in this case
the pointer towards the 'common circuit' was spot on.
I am cautiously optimistic that the culprit has been found - I replaced TR102  and no further
signal drop-outs since then :-))  shall we call it 'CASE CLOSED'  ?!!  Lets have a Party !!!
thank you to all who tried to help
ALF
Page 1 of 1 (7 items) | RSS
