new top Beolab coming after summer/early fall -- 55kEuro
This post has 44 Replies | 3 Followers
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Tue, Jun 9 2015 11:00 PM
Chris Townsend:
I heard the 12-3's for the first time the other day with and without an 11, and I was really impressed....
Chris
Do you prefer the sound of the BL 12.3 with or without BL 11 ?
I have my opinion and I will share after your answer Big Smile
Chris Townsend
Qatar
Posts 3,531
With.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Wed, Jun 10 2015 11:09 AM
@ Chris
Personally, I found the BL 12.3 more dynamic without the BL 11. It seems that BL have a filter that cut the neutrality of the speaker.
Maybe Geoff Martin can inform us ? Yes - thumbs up
Geoff Martin
Struer, Denmark
Posts 672
BeoBoy68:
I don't know what the "neutrality" of a loudspeaker is. I suspect that, if you find that BeoLab 12-3's sound less "dynamic" (I'll assume that this means less "punchy" or with less bass???) with a BeoLAb 11, then the reason has more to do with loudspeaker placement than the actual performance of the loudspeakers themselves. There is also the issue of which of the three positions are set on the switches of both the BL11 and the BL12-3.
Cheers
-geoff
Millemissen
Flensborg, Denmark
Posts 14,680
@Chris and BeoBoy68
How were the speakers connected - respectively?
The 12's to the BL11 and to a BeoSound..?
Or to the dedicated PL-outputs of a BeoSystem -  if yes, to a BSys3 or 4?
It all matters - in addition to, what Geoff already mentioned.
Page 2 of 2 (45 items) < Previous 1 2 | RSS
