Hi all!
I have a video BeoVision Avant 32 ", little use, perfect image, colorful, wonderful as you know .....
The problem is that a few days off for no reason, red dot is on standby and I have to start again, after a while it is the same ....
Anyone know if this is serious, I'm out BeoVision?
that blow!
thanks
The Avant has a fault protection circuit, appears to be shuttng down due to an internal fault.
