BeoSystem 5500 Remote, disassembly or repair instructions?
ummagumma
Posts 26
ummagumma Posted: Tue, Jun 23 2015 6:19 PM
Hello,
I just bought a Beosystem 5500, everything appears to be working but the REMOTE CONSOLE had very old batteries; when I pulled them out a lot of dried battery acid flaked off & fell into the unit
I want to pull it apart and clean it out, so nothing gets corroded. I can feel bits of the dried acid grinding if I turn the volume wheel
has anyone opened one of these? if so, is there anything I need to be careful of? and is is a complicated procedure
thanks!
Die_Bogener
Posts 192
Just remove 5 bolts on the underside. Watch the length, they are different.
The red infrared plastic cover has some small hooks, open it slowly like a hinge.
Remove the power Cords (just pull!)  and the infrared wires. Watch the connector or pull them completly out.
Voila!
5500 and 6500 parts are compatible... ;)
ummagumma
Posts 26
ummagumma replied on Tue, Jun 23 2015 7:48 PM
ah, great!!
it was late @night, I didn't see the bolts thanks!!
ps does anyone know where I can get a n*****
cheers
***** Edit by Dillen.
Please upgrade membership level to at least silver to place wanted ads.
Page 1 of 1 (3 items) | RSS
