Evening people
my beovision 1 with DVD and LCD has stopped working , I turned it on and I get sound but no picture I have checked all the connections but nothing please please help my its my pride and joy
thanks in advance
Beovision1shenley: Evening people my beovision 1 with DVD and LCD has stopped working , I turned it on and I get sound but no picture I have checked all the connections but nothing please please help my its my pride and joy thanks in advance
Welcome to Beoworld!
Can you get a grey screen with the TV button (old analogue channel)? Have you had the TV disconnected from the mains (resulting in the WAIT message after the PIN request?)
It could be a tube failure, but a displaced scart plug can give no picture with sound or vice versa. If you conclude that it is a tube failure and you really like the TV and its stand I would just get a replacement via eBay.
Graham
I've tried two near identical replies, but they've inexplicably gone for moderation.
Check scart connections very carefully as a partial displacement can give sound with no picture. Can you get a grey picture using the old analogue TV button?
hi graham
i have tried everything and still nothing just a jet black screen , taken the back off and gave it a hoover and made sure everything was ok , i have also been told i might be the line input transformer ???
A
Beovision1shenley: hi graham i have tried everything and still nothing just a jet black screen , taken the back off and gave it a hoover and made sure everything was ok , i have also been told i might be the line input transformer ???
I would guess that buying another BV1 or BC1 on eBay is going to be lower in cost than getting any module changed by a B&O dealer.
Great TV: I wouldn't change my pole mounted BC1 and would certainly look for a secondhand replacement if anything failed.
