Hi there my beomaster 1700 that i bought on ebay has problems with the sliders one seems slack and the other has jambed up
Any help would be apreciated
I recently serviced my Beomaster 1700 because of that exact problem, the tracks seamed to slack a lot.
In my case i didn´t need replacement tracks, just some twinkling to prevent the tracks from going loose.
So my advice is, if you have the necessary skills, to open your device and try to understand the source of your problem. The mechanical system that supports the tracks it´s pretty simple and easy to deal with. All you need it´s a lot of patience!
If you need replacement tracks there is another topic on that subject.
http://archivedarchivedforum2.beoworld.org/forums/t/34704.aspx
Hope that you can solve that problem and enjoy your Beomaster 1700, one of my favorites.
