Beocom 4 or Beocom 6000?
This post has 3 Replies | 0 Followers
Rivenflush
Gothenburg
Posts 333
Rivenflush Posted: Fri, Jul 31 2015 9:40 PM
moving into the new house and a prereq to get Internet before we install fiber is to have a landline. Thus, I now have an opportunity to buy a Beocom and was wondering about the differences between Bc4 and Bc6000?
Leaning towards the 6000 as I like the one in white.
(A Bc2 is of course a potential option but as we will only keep the phone for some months I am not sure if it's worth it)
Br
Riven
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Dave Farr
France
Posts 2,283
Dave Farr replied on Sat, Aug 1 2015 11:07 AM
Hi Riven,
if you know that you won't keep the phone later, I'd just go for the cheapest option of the two.  The BC4 is much smaller than the BC6000 so the buttons are much smaller and more fiddly to use - also less clear to read them as the numbers tend to wear off which they don't on the BC6000.  Sound quality of both phones is very good.  You need the master base for the BC6000 but if you like this option, if you decided to keep it you can extend it with extra handsets.  You can also use the BC6000 as a remote for your other B&O AV products which you can't with the BC4.
The BC6000 always seems to be in demand (possibly more so than the BC4) so resale may be easier with the BC6000?
Dave.
Rivenflush
Gothenburg
Posts 333
Thanks Dave, remote control possibility tips it over to a BC6000
Dave Farr
France
Posts 2,283
Rivenflush:
I use mine all of the time for that. When I get a phonecall I can just turn the sound down and don't have to hunt for the BEO4.
Dave.
Page 1 of 1 (4 items) | RSS
