Hi Friends,
What's the best way to connect a playmaker to a beosystem3 to airplay to the Beolabs connected to the besosystem ? There's no AUX socket in the Beosystem3, only Twin RCA IN...
Thanks in advance.
I guess you could use a convertor to the BS3 or possibly depending on which Beolabs you have, if you have an spare Powerlink socket on a Beolab, just go directly from the Playmaker to the Beolab and if they are daisy-chained that could work. So you just bypass the BS3.
I asked a question a while ago about using 2 sources (including a Playmaker) directly to one Beolab but didn't really get a qualified reply but some think this will work - though I never actually tried it in the end. I wanted to use an Ouverture and a Playmaker into one pair of Beolab 4000's.
Dave.
