Hi there,
I am looking to buy a Beocentre and would really appreciate some advice on which speaker and Beocentre combination is best. From looking at what's available I am guessing the 9500 with Redline seekers would be the choice but some educated advice would be great.
Thanks for your time. Grant
I would, if after one system, () would get a BC9500 with a Beolink 7000 and some really nice passive speakers - if possible I would have M75s. I would get the best I could - I would probably ask Lee to source these to give me a guarantee and I would have a Beogram 4000 (non remote, but you have to clean the record anyway!) for listening to vinyl. I would have a Beoport so I could attach to my computer and would be happy knowing I had the most ergonomic Beocenter made. I would get a lot of microfibre cloths to keep it clean!
Peter
Yes the BC9500 is a lovely bit of kit combining beautiful user interaction in addition to strong performance. They are of an age now where either many have issues as mentioned above or have already been repaired. It depends on your budget and maintenance skills. Door, tape and cd issues wouldn't bother me as much as overall cosmetic condition as I enjoy taking things apart! There is a wealth of help on this forum to assist.
However, if the repair route is not for you then I would source one from one of the resellers. Member Joeyboygolf is a specialist on this model and also a reseller but I'm unsure if he is still as active in the refurbishment of them.
If you think nobody cares, try missing a couple of payments.
Thanks for your swift response.
I fell in love with the Beocentre when It was in a house I stayed in as a kid, it had the mirrored top and always fancied one. I essentially need the amp and remote control with aux to input a laptop or ipod but from the research I have done i didn't see any beomasters with remote controls. The Beocentre would look lovely on my wall too. I'm an engineer so should be able to carry out repairs.
Thanks again Grant
Beomaster 7000 and Beolink 7000 would probably be the best option then - most modern software of this era and will be able to work to control the computer remotely - less to go wrong but not as cool to look at!
Thanks for all the advice. It has always been the Beocentre I thought of so I will get one of these. Can someone please tell me the difference between the 9300 and the 9500 and anything in between. Also can anyone advise on speakers to go with a 9500, probably just the main speakers for now.
Thanks for taking the time to help out in advance.
Grant
Hi.
The 9300 vs 9500 discussion has been had many times here before and it really depends what you want from your system. The 9300 is often seen as the poorer cousin of the 9500 and it certainly isn't as well spec'd internally. It doesn't have a phono stage amp to connect a turntable, the tape deck isn't quite as good and it doesn't have 2 way remote control. However, I have had a 9300 for 4 years and am delighted with it. I knew it wasn't quite a 9500 but the 9300 is newer and - arguably therefore - more reliable. The CD player is supposed to be better and I have mine connected to a pair of BL8000 speakers, this combination is one of the great looking B&O systems. Before the BL 8000 I had a pair of passive speakers connected and never had any complaint with the amp.
All of the 9000 series centres have their faults- cd lasers, tape belts, doors not closing etc. but get a good 9500 or 9300 and I don't think you will be disappointed with either.
Enjoy your system whichever one you decide on.
Graeme.
In many ways, the 9300 took an Ouverture and combined it with the 9500 amplifier in a redesigned 9500 box. This has advantages with spare parts! The 9500 is just a bit cleverer and this is what appeals to me. You get more radio channels on the 9300 but the tape is a lot better on the 9500 and the CD is debatable. Both are excellent.
Am I right in thinking that the CD is easier and cheaper to repair on the 9500 (most likely the c2103 cap) against the 9300 which has smd caps and normally is a whole mech swap from a donor?
I note on eBay a lot of Ouverture's for sale with CD faults.
Thanks for all the help. I will get on the case and get my music sounding awesome.
Please let us know what you choose
There are three B&O products that in my mind, best define the company's history... Beogram 4000 for "vintage" B&O. And Beocenter 9500/BeoLink 7000 are probably the single best embodiment of the most awe inspiring and technically sophisticated era for the company. Period, end of story.
Combine them with a pair of BeoLab Penta 3 speakers as is the setup that I have, and you still have a system that 25 years on elicits absolute amazement and appreciation from anyone who sees *AND/OR* hears it.
Much like a fine vintage automobile, all of these products have their finer points which need attention at least once... And carrying the "vintage automobile" theme forward another step, you will be fascinated even in the SERVICING of a 9500 for the first time, how it opens up for service much like a car! Glass panels re-glue will be the most annoying of the common issues to deal with on the 9500. I had a bad CD player in one and just swapped a CD unit from another one. If you use it close to some plasma televisions, the remote control range will be adversely affected as I found when I had my F8500 Samsung plasma turned on (it was always right underneath it). The 7000's primary fault lies in the capacitors for the IR emitter/receiver section that go bad, and the electroluminescent backlight that sometimes dies. The battery is replaceable with relative ease. There are a few people around the world who are capable of repairing these (and other B&O vintage items). The Pentas will often need the mid range speaker section refoamed.
The 7000 is, unfortunately, not the most practical in daily use as it is just fun to play with and look at. You will achieve the most function with a 7000 remote if you can get the ultra rare charging stand. Otherwise it will just sit around on your coffee table where its easily at hand and discharge over time. Keep a Beolink 1000 around, they're dirt cheap and handy to have.
Note about the 7000 stackable system. I had the primarily desirable components to this (CD player and main amp unit) except the Beogram turntable that matches at one point. It has a considerably more powerful and CLEAN amplifier than the 9500 internally which made it a FANTASTIC pairing to my JBL XPL140 speakers. However, for any purpose other than the internal amp, the 9500 will provide more daily enjoyment with its plethora of technological goodies connected to a pair of active speakers, for which my recommendations would be the Pentas first, and the Beolab 8000 second. I had two pairs of RL6000 (the last of the "red line" series mid-tier) and consider them only serviceable in sound quality. These are more of a "party" speaker designed to sit on the floor at an angle and really emphasize the bass frequencies. The Beomaster 4500 in my opinion is only useful if you have space considerations or are just trying to avoid the moving parts in the 9500 and... what is the fun in that?. Early models of the 4500 did not have two way communication, either.
I agree completely with all that is said by Playdrv4me - very well put. I still use Pentas and love them. Cheap now!
Very comprehensive thanks for taking the time to share your knowledge.
Stonk: Am I right in thinking that the CD is easier and cheaper to repair on the 9500 (most likely the c2103 cap) against the 9300 which has smd caps and normally is a whole mech swap from a donor? I note on eBay a lot of Ouverture's for sale with CD faults.
I will agree with you on the CD mechs. The one in the 9500 is mechanical "solid as a rock". When it fails it is often because of the c2103 cap - or a few other components on the servo board. The newer CD mech in the 9300 is not as solid build - and more difficult to repair if we're talking about changing caps, because of the (as you mention) smd components. But - the good thing is that you can still buy a complete cd- mech for the 9300 (not from B&O, though).
Gregg:Peter - Im loving my BC9500 with floorstand/Beolink 7000 with floorstand/Penta I system. I have a BG9500 that once repaired will join it on the floating shelf. It will be the center of a whole house MCL system. How do I connect the ML beoport to it? With the ML/MCL convertor? The BL7000 doesnt have N.Music or N.Radio.
I have a converter and the 7000 will have Tape 2 which works as N.Music
Hi Grant,use the information provided here in the forum and then listen to your heart which Beocenter to take. BUT - as many Beoworld members will know - sometimes you'll need earplugs to stop listening to your heart, because it will love MANY Bang & Olufsen things and keeps telling you "Hey, you NEED to buy this one, too!". That's the dark side of Bang & Olufsen... it's like a virus you don't want to be cured from.
The infection has had a name for a few odd years: it's called the beovirus. It has also been known that there is no cure.
Jacques
chartz:The infection has had a name for a few odd years: it's called the beovirus . It has also been known that there is no cure . Jacques
Since B&O stoped producing sound systems made of aluminium, I would also consider the Beocenter 2 as one of the last design pieces from a previous time period...
