Would any fellow members here have a spare aerial DIN45316 plug for my Beomaster 5000 tuner by any chance?
I've tried ebay, etc. but no cigar.
Thanks!
Jacques
D ?
Yes indeed Martin! D it is.
If a used one will do, I will throw one in the package with the other things.
That'd be great!
By the way Martin, do you have a few rosewood/palissander veneer chips I could use to fix the Beomaster lid?
I think I'll also buy the signal meter, because mine is not very clear. Is yours fully transparent?
Yes, nice and clear.It looks a bit dirty above the dial in the photo, I don't know why. It's not.It has a very superficial mark below the 60 mark, it will polish away fairly easily if you want or youcould just leave it. I can't catch it with my camera.If you want the meter, please order through Bonanza, I would really like to support thischeap, friendly and great alternative to Ebay.
I will also see if I can find some palisander chips, shouldn't be too impossible.
Done. Thanks!
