BeoLink question
This post has 50 Replies | 1 Follower
Razlaw
Posts 4,345
Razlaw replied on Mon, Sep 14 2015 11:07 PM
mjmedlo:
Razlaw:
Sound in one room? Both rooms? Nothing? Will I need to turn system n in one of the rooms with the Beo 4 and join the Moment so a two step process?
The speakers connected to the moment will start
Otherwise nothing else.
See the moment just like you see your BS5. It's a source that you start then join others to.
In your scenario, you'll name v.aux2 for instance as tune in on the NL/ml converter.
Then when you start radio on the moment and select v.aux2 on an ML product.... You'll have tuneIn.
Hope this helps.
Thanks!  It would be slightly different than the Beosound 5. If I select a source directly on the Beosound 5, it turns on the speakers connected to the TV that is identified as the Video Master. So with no speakers connected directly to the Moment, I would not be able to turn anything on from the Moment?Would the volume wheel on the wood work once the speakers were playing?
Razlaw
Posts 4,345
Razlaw replied on Tue, Sep 15 2015 12:41 AM
You stated
Does that mean I would not be able to turn the moment on with the Beo 4? It would always be a two step process? Turn the Moment on and then select it on the Beo 4?
As opposed to now when I select a source on the Beosound 5 with one press of the Beo 4 and the appropriate speakers turn on and the Neosound 5 turns on?
mjmedlo
Posts 922
mjmedlo replied on Tue, Sep 15 2015 12:48 AM
Not necessarily.
If you set v aux.2 to Tune In on the converter and the converter connects to the moment
Then you'd get tune in from your ML product based upon that button press.
You would not get sound from the moment for direct interactions don't think.
I am not positive about that but I don't think you'd be able to use the TV speakers as the moments speakers ... Honestly I'm not quite sure.
I have a passive kit and in wall speakers connected to mine so I'm not sure exactly how that works.
Razlaw
Posts 4,345
Razlaw replied on Tue, Sep 15 2015 12:56 AM
May just have to take advantage of dealer's 30 day return policy and order and see how it works.
Thanks for all of the input and assistance.
mjmedlo
Posts 922
mjmedlo replied on Tue, Sep 15 2015 10:01 PM
Razlaw:
Price of the moment is not bad.
Go for it!
It's actually quite nice.
Razlaw
Posts 4,345
Razlaw replied on Wed, Sep 16 2015 12:08 AM
I am still having a difficult time grasping how my system would work with a Moment or an Essence.
I have a BV7 and BV10 and BS5 connected by Masterlink. I also have a stand alone V1
If I purchase an Essence and one converter, would I be able to Press a button on the Beo 4 to turn on Spotify from the Essence in the room I am in and have it play through the TV's connected speakers just as with my BS5, but then with the added benefit of being able to use the app to search for and select music?
Same question with a Moment and Deezer?
Thanks!
mjmedlo
Posts 922
mjmedlo replied on Wed, Sep 16 2015 12:52 AM
Razlaw:
Thanks!
No for essence and spotify
Yea for moment and deezer
Spotify won't distribute but deezer will.
Razlaw
Posts 4,345
Razlaw replied on Wed, Sep 16 2015 1:49 AM
Spotify wont distribute from the Essence? It distributes from the Beosound 5. If it wont distribute form the Essence to connected devices, what is the purpose of having it on the Essence? Are you saying Spotify will only play through speakers connected directly to the Essence?
Thanks!
mjmedlo
Posts 922
mjmedlo replied on Wed, Sep 16 2015 3:25 AM
Spotify is analog on bs5
Digital on essence mark 2
If ou want spotify distributed.. Connect an essence mk1 to your line in on BS5 and distribute away!
Razlaw
Posts 4,345
Razlaw replied on Wed, Sep 16 2015 3:41 AM
So what is an Essence MK2 capable of doing with Spotify? Again thanks. I am finding NetLink, Essence and Moment very confusing.
Razlaw
Posts 4,345
Razlaw replied on Wed, Sep 16 2015 3:43 AM
mjmedlo:
I am sorry for my confusion. I can already distribute Spotify from my Beosound 5. What would connecting an Essence MK1 to it add or change?
Page 2 of 2 (51 items) < Previous 1 2 | RSS
