Beoplay a9 1st generation - wireless setup with android
slbru
Posts 2
slbru Posted: Wed, Sep 30 2015 8:16 AM
A9 owners' kind advice is required:
In order to finish the setup of the A9 (1st generation), I need to enter wifi network password in the b&o setup app for android installed on the Sony Xperia z3. The line next to the word "password" remains inactive which does not allow entering a password, and this is where the setting up stopped every time I tried.
Could you please advise a solution?
Aussie Michael
Melbourne, AU
Posts 3,730
Hi
I also have a Sony Xperia Z3 which i now use as my BeoRemote :-)
I don't have an A9, but i have looked at the app
When you're in wifi, did you select BeoPlay A9_xxxxx?
When you go to input your password, is the keyboard visible?
slbru
Posts 2
slbru replied on Wed, Sep 30 2015 9:10 AM
Hi Michael,
Yes, I selected the BeoPlay a9 in the wifi setup menu. Then I selected my home wifi network
In the beosetup app, but I could not proceed further as the wifi password line is inactive, and when I tapped on it the keyboard does not appear on the screen.
Aussie Michael
Melbourne, AU
Posts 3,730
Sometimes you can enable the keyboard from the bottom of the screen if it doesn't show up
Dave Farr
France
Posts 2,283
Dave Farr replied on Wed, Sep 30 2015 11:41 AM
Hi Michael,
I assume you've looked through the FAQ's on the Beoplay A9 site?  If not, it's here:
http://bogo.custhelp.com/app/answers/list/p/7,809#s=eyJzZiI6eyIxNzYiOnsiZmlsdGVycyI6eyJub190cnVuY2F0ZSI6MCwicGFnZSI6MSwic2VhcmNoVHlwZSI6eyJmaWx0ZXJzIjp7ImRhdGEiOjUsInJuU2VhcmNoVHlwZSI6InNlYXJjaFR5cGUiLCJmbHRyX2lkIjo1fX0sImtleXdvcmQiOnsiZmlsdGVycyI6eyJkYXRhIjoiIiwicm5TZWFyY2hUeXBlIjoia2V5d29yZCJ9fSwicCI6eyJmaWx0ZXJzIjp7ImRhdGEiOnsiMCI6IjcsODA5In0sInJuU2VhcmNoVHlwZSI6Im1lbnVmaWx0ZXIiLCJmbHRyX2lkIjoyfX0sImMiOnsiZmlsdGVycyI6eyJkYXRhIjp7IjAiOm51bGx9LCJyblNlYXJjaFR5cGUiOiJtZW51ZmlsdGVyIiwiZmx0cl9pZCI6M319fX19LCJjIjoxMn0.
No mention of setting up with Android though!  But it is on the quick set-up guide:
http://www.beoplay.com/~/media/ManualsPDF/BeoPlay_A9/3511168_1210-QG-BeoPlay-A9_web.ashx?la=en
Are you sure you have a green light whilst doing this?
If you've tried unplugging the A9 and starting again, if it still won't work, just send a message to the Beoplay support people asking them what the problem may be.  It's possible there may be a setting on your phone related to passwords and whether they are asked for or not?
Contact them here:
http://bogo.custhelp.com/app/ask/session/L3RpbWUvMTQ0MzYwODk3Mi9zaWQvdXgzQVdMeG0%3D
Dave.
Lobsterman
Posts 4
Hi you all.
I just can't send my deezer music from my Xperia Z3.
The set up is complete and the A9 is seen connected in Beosetup.
But I don't know/ find the way to transfer.
It works well with an old iPhone though.
Thanks for your help.
Millemissen
Flensborg, Denmark
Posts 14,680
How did you send/transfer it from the iPhone?
Lobsterman
Posts 4
Lobsterman replied on Fri, Dec 11 2015 10:45 AM
With the iPhone, I transfer the music with the airplay icon.
I just installed the All connect app on my Xperia and I can now read the music on the A9.
But still not with Deezer.
Millemissen
Flensborg, Denmark
Posts 14,680
Your Android phone does not support AirPlay!
The All Connect app only supports media locally stored on the device, where the app is installed.
If it works well with your iPhone/AirPlay, why not just stick to that?
Page 1 of 1 (9 items) | RSS
