Beosound 9000 & Beolab 8000
This post has 5 Replies | 2 Followers
SLiddell
Posts 2
SLiddell Posted: Thu, Jun 21 2012 4:18 PM
Hi all,
I have just moved from the US to the UK with these units, purchased new in 1999.  As they are US units, they are set up for 110V. Can anyone advise on how to convert them for use on 240V?
Many thanks
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Thu, Jun 21 2012 5:06 PM
The cheapest way is to get a 240/110 transformer. I am certain they can be converted to 240v but no idea of cost.
tournedos
Finland
Posts 7,357
tournedos replied on Sun, Jun 24 2012 4:43 PM
The Beolabs aren't too difficult; you need to cut a couple of traces on the transformer PCB and solder in a couple of jumper wires (originally the circuit board has everything connected - at the factory, they just cut a few places according to the target voltage). These points are described in the service manual. As I'm an idiot, I don't think I took a single photo of the process Sad
Having this done for the Beolabs makes sense, as they need more power and having bulky transformers at each speaker isn't too convenient. The Beosound might be easier to set up with a step down transformer, I have no experience with converting that. According to the service manual, the US 120V version of the Beosound seems to have a different transformer and even a different part number for the power supply module, so it might not be cost effective to convert it.
--mika
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Jun 25 2012 12:11 AM
tournedos:
Interesting comment on the Beolabs. Do you have any idea how hard it is to convert Pentas or Beolab 1's? I ask because it's rare to find BL 1 on thos side of the pond at all, and most of the Pentas are very rough. Here being USA.
Jeff
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Jun 25 2012 8:26 AM
Jeff:
Well... no Big Smile
I could take a look in the service manuals on site, but I try to avoid commenting the difficulty of things I have never done nor seen myself.
Even for the 8000s, the actual conversion is the easiest part. All the work is getting the speaker open and struggling with the dampening material, which after 10+ years closely resembles something you could make by taking pieces of plastic foam and cooking them overnight in glue and black paint.
--mika
SLiddell
Posts 2
SLiddell replied on Mon, Jun 25 2012 9:40 AM
Many thanks for the advice. I will try this out.
Page 1 of 1 (6 items) | RSS
