Hi
would you be kind enough to measure the dimensions of your bv 12 65 floor stand if you own one.
i can't find the information online.
thanks
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
I tried to post a schematic and failed horribly.
The depth of the base of the floor stand (front to back) is 49.9cm
Height from floor to top of Bvis 12 is 132.1 cm plus 0.6cm for the display panel on top of the screen.
Regards
Opman
Hi opman,
fast and precise
thanks a lot !!!!
Are you considering getting one of these great BVs ?If I had the room I would have one.
