My current set up:
Beolab 18, 19 + 15 (ceiling mounted as rear speakers), 4000 in zone 2 - all connected wirelessly via transmitter 1 - connected to Marantz receiver.
I would very much enjoy adding a "moment" however, I was told that the only way this could work would be to connect the moment to my Marantz and assigning an input. This then would mean I would have to turn on the Moment and then turn on the Marantz.
This in my opinion would defeat the purpose and I might as well use the Deezer on my i-phone and air-play it via my playmaker.
Am I overlooking the obvious? Is there a way of connecting a Moment so that it was instant on like it is meant to be?
Tifoso48: My current set up: Beolab 18, 19 + 15 (ceiling mounted as rear speakers), 4000 in zone 2 - all connected wirelessly via transmitter 1 - connected to Marantz receiver. I would very much enjoy adding a "moment" however, I was told that the only way this could work would be to connect the moment to my Marantz and assigning an input. This then would mean I would have to turn on the Moment and then turn on the Marantz. This in my opinion would defeat the purpose and I might as well use the Deezer on my i-phone and air-play it via my playmaker. Am I overlooking the obvious? Is there a way of connecting a Moment so that it was instant on like it is meant to be?
If your Marantz receiver has a trigger input, maybe sounds heavenly can help you with a wire which can double your power link out, to not only trigger the speakers to on, but trigger your receiver to ON when you turn on your moment. That means that the wire(s) or split wires connected to both your MOment's power link OUT as well as as trigger input for your receiver. But I'm not familiar if the receiver can receive trigger inputs. I know for the most part that receivers can transmit trigger commands.
