Centre weight ( stabiliser )
This post has 5 Replies | 2 Followers
bramble
Posts 397
bramble Posted: Wed, Oct 28 2015 4:58 PM
Hello,
Does anybody know if these can be used with a beogram. And do they make any difference that the normal ear would be aware of, or would the vinyl benefit from it.
Also would the added weight (280-300g) burn out the motorAngry
Thanks for any reply
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Wed, Oct 28 2015 5:26 PM
Don't bother. Puts excessive pressure on the platter bearing and no doubt stresses the motor more at startup. I'd be surprised if you could hear any difference anyway.
bramble
Posts 397
bramble replied on Wed, Oct 28 2015 5:28 PM
Thanks lee , thought it would .
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Oct 28 2015 6:57 PM
Also on the later tangential beograms that use the weight of the record to determine the size (and thus drop point for the arm) adding a weight on 7" records would likely result in a destroyed cartridge!
Martin.
riverstyx
SouthWest UK
Posts 938
Martin.
Mark
London
Posts 1,063
Mark replied on Thu, Oct 29 2015 12:32 PM
I have a couple that weigh in at 410grams... I just use them as desk paper weights as they are beautifully machined aluminium, I agree with the above comments and thought they were more a DJ thing to reduce skipping .....
Page 1 of 1 (6 items) | RSS
