New TV non B&O but with B&O loudspeakers
This post has 3 Replies | 2 Followers
Raeven
Posts 61
Raeven Posted: Sun, Nov 8 2015 8:40 AM
Hello,
I am looking  for a new TV but I do not like the design (and price) of the Beovision Avant 75. What is the best solution if I want to keep my B&O  surround loudspeaker setting with a new TV?.
Presently I have a BeoSystem 3 with a Panasonic Kuro screen, is a BeoSystem 4 with an other screen a solution?
Or does somebody know a surround system to which I can connect the B&O loudspeakers?
TWG
Posts 1,672
TWG replied on Sun, Nov 8 2015 10:15 AM
You can use an external surround pre-amplifier and connect the Beolabs to the pre-out / line out of the channels.
If your Beolab speakers have a line-in RCA input, you simply switch them to "line-in" and you should be done. If they only have Powerlink input, you may need a trigger output to activate them. Most better pre-amplifiers should have trigger outputs, too. It could be that there's an adapter cable required. If yes: Please ask Steve from Soundsheavenly.
Millemissen
Flensborg, Denmark
Posts 14,680
If you want to stay with the way B&O deals with sound, setup, interfacing, remote, puc etc, you should consider the BSys4.
But why not just stay with the BSys3 and change the screen/tv?
Do you want something, that the BSys3 does not already offer?
If yes - what?
OldJack
Split
Posts 371
OldJack replied on Sun, Nov 8 2015 6:52 PM
Right, as MM says,why not to use BSys3?
I am using 4K Samsung 55 inch led tv with BSys3 and Beolabs. BSys 3 used as speaker terminal/sound sources only.
Video sources handled by tv. This way,I am very happy with entire setup.
OldJack
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Page 1 of 1 (4 items) | RSS
