Beolink Gateway supported home automation systems
tradingman
Posts 41
tradingman Posted: Sun, Nov 22 2015 8:03 AM
Good morning everybody,
Is the an information from Bang Olufsen which drivers for the home automation systems are supported? On beointegration website there are only a few systems listed. Beophile.com says there are hundreds of driversUnsure
Thx
Regards
beojeff
USA
Posts 2,012
beojeff replied on Sun, Nov 22 2015 4:04 PM
On the BeoIntegration site you can find the manuals for the BLGW and MLGW. They describe the various systems that work with the gateway. You might want to take a look at the Lutron RadioRa 2. I find it to be very easy to install and much more affordable than the other systems. Most systems are "closed" so that only qualified dealers can do installations and make changes. If you can get your hands on the Lutron Windows software, it's very easy to install the dimmers, switches, and power modules yourself.
Page 1 of 1 (2 items) | RSS
